Request: Line Profile Reset
- Re: Request: Line Profile Reset
10-11-2015 9:09 PM
It appears that BT (Openreach) have finally resolved the problem with noise on the line, however my once blisteringly fast 3mbps has now dropped to around 0.1mbps. I politely request that my line profile is reset in the hopes that I might once again reach the dizzying heights of 3mbps.
Thanks!
Thanks!
Message 1 of 7
(1,052 Views)
6 REPLIES 6
11-11-2015 9:20 AM
Taking a look now, sounds like you're aware that the phone fault has likely impacted the broadband so let me see what we can do.
Message 2 of 7
(731 Views)
11-11-2015 9:22 AM
Oh trust me, I'm fully aware that this is BT's (Openreach's) fault, it usually is
Thanks for having a look
Message 3 of 7
(731 Views)
11-11-2015 10:11 AM
I've reset the line, but need to give your profile a nudge on our systems but they are running a tad slow at the moment, I'll sort that as soon as I can.
Message 4 of 7
(731 Views)
11-11-2015 10:13 AM
Thanks very much for all your help Chris, so glad I chose plusnet for my ISP
Message 5 of 7
(731 Views)
11-11-2015 10:46 AM
If you disconnect/reconnect you should see an improvement in the speeds again.
Message 6 of 7
(731 Views)
11-11-2015 11:23 AM
Thanks Chris I've done that, crossing my fingers my line remains relatively noise free
Message 7 of 7
(731 Views)
