Req defnition of difference between Plusnet Premier £21.99 and 'Unlimited'
suec45
Hi, I am wondering whether to save some dosh by moving from Premier 1 to 'Unlimited'.
1. Is the service basically the same? (if not what changes can I expect, I am not clear on what legacy premier 1 is right now)
2. Do I save around 10 a month for the first 3 months and then around £3 after that?
3. DO my referals still carry over?
4. Do I get any extra charges for changing?
Thanks for your help Smiley
Fixes: 10
Re: Req defnition of difference between Plusnet Premier £21.99 and 'Unlimited'
Traffic shaping is very different.
http://www.kitz.co.uk/isp/plusnet_shaping2.htm will show you the differences.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
James
Hi Suec45,
- As Jelv has pointed out, the traffic shaping is different.  Use the link he's posted.  Obviously there's also no usage allowances.
- Yep, if you're on a Market 3 exchange, otherwise it's £10 saving for the first 3 months and a £2 saving afterwards.
- Yes they will.
- No charges, but you would be committing to an 18 month contract.
suec45
Thanks guys Smiley)
