Replacing that dreadful router!
- Re: Replacing that dreadful router!
06-11-2013 1:13 PM
I am a very new PN customer. So far, an abysmal service: missed appointments; technical errors (phone not connected before fibre install), etc..... truly awful service. Made Sky look competent!
Its all now set up and working but the supplied router is awful. Awful looking (cheap and nasty) and awful wifi signal.
I am looking to bin this piece of garbage asap.
- Can I use any of the BT Home Hub 3, 4 or 5? Will PN assist me with all the settings I need?
- Anybody else done this? What router did you go for? I'm thinking Asus RT-N56U but it is a bit expensive!
I know I need to wait 10 days for the line to 'train' and all that but the wifi signal is the wifi signal, surely!?
Many thanks.
06-11-2013 1:30 PM
Sorry you're not happy with the router, but yes - any of those home hubs will work fine with our service, all you need is your username and password for the router. Username will be accountusername@plusdsl.net and your password the same one you use to log in to our website.
There's a fair few others on here who do like the Asus routers though if you opt for one of those, there's a couple of threads in this board about them too
Hope that helps, and sorry about the bad start - hope things get better from here.
06-11-2013 1:40 PM
Quote from: pattojones missed appointments
Did you get any compensation?
06-11-2013 2:01 PM
jim:quote
06-11-2013 7:04 PM
http://community.plus.net/library/hardware/using-a-bt-homehub-3-or-2-on-plusnet-adsl-or-fttc/
06-11-2013 10:17 PM
My cheaper option
06-11-2013 10:22 PM
Not cheaper as it uses more power if you have 2 routers on , simpler to just use bt hub in its own connected to Plusnet
06-11-2013 10:31 PM
not really going to hurt the bank
06-11-2013 10:36 PM
06-11-2013 10:46 PM
Every little helps.
Some people can't afford to just throw money about!
06-11-2013 10:51 PM
I'd definitely recommend this coupled with a simple ADSL/VDSL modem.
07-11-2013 9:25 AM
Quote from: thesawdust What does a router cost to run?
using "close approximations" 1W continuous is 8.76 units per annum, so between £1.05 and £1.40 per annum per Watt (from current tariffs checked)
Rule of thumb: no more than 8.76*<pence per unit>*<W rating> or £1 per annum per Watt at 11.4p per unit - £1.50 @ 17p per unit
07-11-2013 3:36 PM
07-11-2013 6:05 PM
09-11-2013 9:47 PM
Quote from: markm9 i replaced my PN router with the Asus RT-N56U, a couple of months ago, as i found wireless coverage wasnt the best with PN router, also only supports 2.4GHz, Asus supports both 2.4, and 5 GHz, wireless coverage excellent, also not bad looking router, yes it cost me £80 from amazon but well worth the money
Do you use anything special by way of firmware on the RT-N56U? Looking at this and also the N66U (seems bit excessive for my needs) and just wondering if the default stock FW will be reliable enough w/o too much tweaking?
I'm remote from the site but have non tech users there as well, so need something dependable but with good wireless perf....been disappointed with the Technicolor on the latter.
