Replacing my TG582n
buckethand
Replacing my TG582n
Hello,
        Having poor wifi coverage from my TG582n with 8.4.4.J FW - I've run inSSIDer and get a constant -82 with drops below that at times and this is only through 2 walls and max distance of about 7 metres - has anyone swapped out their router and if so what advice would you give? The ASUS dual band seems to have good reviews here.....thanks for your help.
Regards
Mike
Fixes: 20
Re: Replacing my TG582n
If you search this sub forum you will see that LOTS of us have replaced it.
A HH3 or 4 if you can get it is a good option. I use a Netgear N300, others the Asus, depends really on how much you want to spend.
Fixes: 4
I'm on fibre using the Asus RT-N56U & am very pleased indeed.  Smiley
