Replacing my TG582n
- Replacing my TG582n
Replacing my TG582n
30-07-2013 11:07 AM
Hello,
Having poor wifi coverage from my TG582n with 8.4.4.J FW - I've run inSSIDer and get a constant -82 with drops below that at times and this is only through 2 walls and max distance of about 7 metres - has anyone swapped out their router and if so what advice would you give? The ASUS dual band seems to have good reviews here.....thanks for your help.
Regards
Mike
Regards
Mike
Message 1 of 3
(857 Views)
2 REPLIES 2
Re: Replacing my TG582n
30-07-2013 11:10 AM
If you search this sub forum you will see that LOTS of us have replaced it.
A HH3 or 4 if you can get it is a good option. I use a Netgear N300, others the Asus, depends really on how much you want to spend.
Message 2 of 3
(269 Views)
30-07-2013 11:24 AM
I'm on fibre using the Asus RT-N56U & am very pleased indeed.
Message 3 of 3
(269 Views)
