Replacement router for technicolor? Cable?
mattprince
What router spec do I need if I want to replace the Technicolor? Do I just need a cable router as the Technicolor doesn't have the dsl plugged into that anyway?
Matt
7 REPLIES 7
HairyMcbiker
All Star
Fixes: 21
Re: Replacement router for technicolor? Cable?
You want one that has gigabit ports, that way it will be fast enough to cope with the higher speed, wireless n, and ppoe.
Most modern cable routers will have this. I use a Netgear N300 well pleased with it. Others recommend some Asus and TP-link ones.
mattprince
So as long as its got gigabit Ethernet and its a cable router im fine? No need to be adsl?
HairyMcbiker
All Star
Fixes: 21
Opps. Sorry if you are on adsl then yes you need an adsl router, I was assuming fibre - wrongly?
DrDave
Matt - what broadband connection do you currently have?Huh
mattprince
Im on fibre
DrDave
I'm very pleased with my Netgear WNDR3700 Gigabit router.
HairyMcbiker
All Star
Fixes: 21
Quote from: mattprince
Im on fibre
If you are on fibre then you def DON'T want an adsl router, just a cable version that can handle high speed.
