Replacement router for technicolor? Cable?
- Re: Replacement router for technicolor? Cable?
26-02-2013 10:58 PM
What router spec do I need if I want to replace the Technicolor? Do I just need a cable router as the Technicolor doesn't have the dsl plugged into that anyway?
Matt
Matt
Message 1 of 8
(1,421 Views)
7 REPLIES 7
27-02-2013 9:47 AM
You want one that has gigabit ports, that way it will be fast enough to cope with the higher speed, wireless n, and ppoe.
Most modern cable routers will have this. I use a Netgear N300 well pleased with it. Others recommend some Asus and TP-link ones.
Message 2 of 8
(749 Views)
27-02-2013 7:15 PM
So as long as its got gigabit Ethernet and its a cable router im fine? No need to be adsl?
Message 3 of 8
(749 Views)
27-02-2013 7:16 PM
Opps. Sorry if you are on adsl then yes you need an adsl router, I was assuming fibre - wrongly?
Message 4 of 8
(749 Views)
27-02-2013 9:01 PM
Matt - what broadband connection do you currently have?
Message 5 of 8
(749 Views)
27-02-2013 10:49 PM
Im on fibre
Message 6 of 8
(749 Views)
01-03-2013 7:32 AM
I'm very pleased with my Netgear WNDR3700 Gigabit router.
Message 7 of 8
(749 Views)
01-03-2013 9:04 AM
Quote from: mattprince Im on fibre
If you are on fibre then you def DON'T want an adsl router, just a cable version that can handle high speed.
Message 8 of 8
(749 Views)
