Replacement router for Technicolor TG582n
reserved
Can you suggest a replacement router for the PN supplied one?
Suffering from lots of drops in connection and want to rule out router problems. Am on ASDL2 and need usb port for Netplug.
thunderer
Re: Replacement router for Technicolor TG582n
Have a look here: http://community.plus.net/forum/index.php/topic,131151.msg1143838.html#msg1143838
They're not cheap, but they're worth it. You could also have a look at Asus & Netgear as well.
The Draytek & Billion ones are capable of accepting both ADSL/VDSL, not sure about Asus & Netgear, so check before you buy.
reserved
Thanks for that. As I seem to be suffering the same problem as lots of others at the mo I think I will hold fire until PN's problems are sorted.  Undecided
