Replacement modem
mavebuck
Replacement modem
I have been using the Plusnet supplied Thompson tg585 since I joined at the end of 2009,  For the past year or so my internet speeds have varied between about 0.2 Mb and 7Mb.  I recently borrowed an old router from a relative and since then the speed has been stable.  I wonder if Plusnet would send me a replacement router.
Mavis
Gel
Seasoned Pro
Fixes: 14
Re: Replacement modem
Fixes: 5
Yes I think they will for a £7.99 delivery charge - not sure if it involves a new contract. Though if your generally happy with your connection that is not a problem.
Fixes: 162
Hi there, I can see you've spoken to one of my colleagues since posting here. I hope everything is now sorted for you.
 Chris Parr
 Plusnet Staff
