Replacement for Plusnet router
Muttley62
Can anyone recommend a multicast and ipv6 compatible dual band router to replace the Plusnet supplied one - its poor wireless performance is driving me nuts.  I was all set to purchase the Asus RT-N66U but then I came across some users saying that the wireless performance degraded with time, I don't know if this is a widespread issue or not - it was suggested that it was to do with the operating temperature of the router.
