Replacement Router
richcm
Replacement Router
So deciding that the stock supplied Technicolor POS Router is in fact a POS, are there any recommendations for better routers or anything i should be looking for to replace the one supplied?
hows this one as an example?
http://www.overclockers.co.uk/showproduct.php?prodid=NW-068-TP&groupid=46&catid=1595&subcat=1932
Fixes: 21
Re: Replacement Router
There are already several threads detailing what we recommend.
Have a look through the forum and you will see the answers.
richcm
yeah looking...a sticky would have been nice if it's a highly requested thing
SoFarSoGood
Hi richcm
What makes you think the supplied Technicolor is a POS?
What problems did you have when you tried it?
richcm
well apart from a terrible ui, reset time, build quality and being nearly as ugly as me Cheesy it's great
One thing i have noticed is since it's replaced my old bethere router (same position in house) the Technicolor's signal doesn't even reach the back garden (not that far) like the be router did (kinda essential)
thomasjc1
I got a asus rt-n66u for fibre as well as many others on here and it's brilliant
richcm
Thanks for the suggestion Thomas Smiley
SoFarSoGood
Quote from: richcm
Hi richcm
You don't say if you are on ADSL or FTTC.
If ADSL, I doubt you will fine a basic modem that performs better.
Agree UI not good but once set up does it really matter as all basic information is shown.
Not sure about reset time as mine is on all the time.
Build quality is ok. Even some much more expensive modem/router are 'all plastic'.
Looks/design is a personal matter. I quite like the basic design and also prefer a matt white finish to a glossy black (shows up finger prints, dust etc.).
As your main concern appears to be the wireless performance, I suggest you spend your money on this area e.g run more cable to nearer your main areas of use and/or installing/using Home Plugs and wireless extenders.
All IMO.
richcm
Hi richcm
All IMO.
Sorry Smiley is FTTC
I think i can live with the rest but the WiFi is terrible, so looking at the suggestion above.
mikehiow
I've always hated using Wi-fi until I got an RT-N66U.
100mbps+ all over the house. I can't argue with that.
Fixes: 4
If you want to save some money try the Asus RT-N56U. I love mine & the wireless is amazing. I'm running 2 laptops, 2 Nexus tablets, internet TV, printer & my Western Digital My Book Live constant back up. Everything runs at 100% of my predicted speeds.
richcm
Quote from: mikehiow
In the end went for the same and download speed went from 20 to 30
