Replace hub 2 with Eero 6
- Replace hub 2 with Eero 6
a month ago
I am trying to replace my hub 2 with an Eero 6
I've plugged the Eero directly into my ONT box but I've no Internet
When I plug the Eero in to my hub 2 it works fine
As I want to use the Eero as my only router this isn't a suitable set up for me
Any ideas on how I can just plug the Eero into the ONT without using my hub 2
Re: Replace hub 2 with Eero 6
a month ago
You need to setup the WAN port on the Eero 6 for a PPPoE connection,
The broadband username would be in the format your account name@plusdsl.net the password is the same as used for the members centre.
Hope this helps
a month ago
@tigersb you might find this useful https://support.eero.com/hc/en-us/articles/5382599417371-PPPoE-Setup-Instructions
