Repeated problems since switching to Plusnet
ajsvoice
Hi since joining from Talktalk I have been having repeated problems. The broadband keeps dropping and reconnecting at a very slow speed - it was always a steady 15000 kbps with Talktalk. Also the phone line is very noisy - lots of crackling on the line.
These problems only started when I joined Plusnet - never had any trouble with Talktalk.
Estragon
Re: Repeated problems since switching to Plusnet
Could be a dodgy connection at the exchange, when your line was moved from TalkTalk kit to the BT Wholesale kit.
ajsvoice
I'm thinking along those lines - since nothing has changed at home other than the new Plusnet router.
Plusnet Staff
Plusnet Staff
Fixes: 159
Can you go through the checks here: http://www.plus.net/support/phone/troubleshooting.shtml and use the Phone Troubleshooter if you're still having issues. This reports the phone fault straight to us.
 Chris Parr
 Plusnet Staff
ajsvoice
I've done this but it says there is no problem.
dick:quote
Fixes: 136
From what I can see you haven't used the phone troubleshooter?
If you go through it again it'll submit a report to our Faults team who can investigate further.
 Matthew Wheeler
ajsvoice
I have used it and it reported "We haven't found any problems with your phone line." And I've just tried again with the same result.
Plusnet Staff
Plusnet Staff
Fixes: 159
I can see you've spoken to one of our chat agents, they've given you some info on a ticket. If you can reply at contactus.plus.net we'll be able to get back on to this.
 Chris Parr
 Plusnet Staff
ajsvoice
Thanks I have discovered the ADSL filter was faulty and it has been replaced.
Fixes: 136
Glad to hear you tracked down the cause.
 Matthew Wheeler
