Repeated disconnects
andreas1999
Having repeated disconnections from the internet today. Anything going on?
19 REPLIES 19
Chris
Legend
Fixes: 169
Re: Repeated disconnects
There are a few disconnections showing:
http://community.plus.net/visualradius/generated/image14543188073216.png
Have you tried any troubleshooting yet? http://www.plus.net/support/broadband/bbfaults/
pwdixon
Have you tried the trouble shooter that appears to be permanently unavailable!
dick:quote
cedlor
Seems ok to me- at least as far as confiming my telephone number - does it give uip after that?
Chris
Legend
Fixes: 169
It errored on pwdixon's account but has reported the fault to us anyway, our faults team will get on to that asap.
pwdixon
Quote from: cedlor
This is what I meant (see attachment).
andreas1999
I'll try the troubleshooter as the disconnects are still happening today
andreas1999
Turns out I can't access the troubleshooter. It won't let me log in and the reset password feature just says I haven't types the verification code correctly.
cedlor
It is the login and password for Plusnet  - may be different than for the forum
Can you log into the speed at plusnet link below?
If you get a result with that leave it open then try the troubleshooter - it will (I thnk) see yuo as still logged in.
andreas1999
Thanks! I managed to login and do the troubleshooting. Apparently there is a fault with my line but sounds like it won't be looked at until Thursday. I think the tech people must be very busy.
cedlor
Good at least its some progress- let us know how it goes.
andreas1999
So the internet has gotten much worse since last time. It's been near unusable today. I'm typing this from my phone as the connection is currently down. Last note on my support ticket was that some job would be finished by 12 on Thursday but no word from Support since then.
Not sure how to get in touch with them either. I asked a question on the support ticket but haven't had a response..
pwdixon
It's like a conspiracy, they make it so difficult to contact plusnet.  Even what little contact points there are are buried so deep in their confusing circular website that its almost impossible to get through to them.  Good luck with getting your problem resolved.  sorry to say I'm not impressed with plusnet, sorry I'm not really helping but I wanted to vent and your post came along and was similar to mine
andreas1999
I've had success with their support in the past but perhaps they're struggling to cope these days? If they didn't get back to me during the week I think I'll have no hope hearing from them over the weekend.
cedlor
Yes  even thinner on the ground at the weekend  but you could try the  online "chat"  to see if thay can see anything. Have your ticket number to hand.
