turn on suggestions
Repeated connection drops
- Repeated connection drops
11-03-2011 10:01 PM
My internet connection drops out most days, sometimes several times a day and at random times. Usually it fixes itself after a while or after a router restart. I was using the issued thomson router though have recently switched to a TP-Link W8960N and am still having the same issue so I'm guessing it's not a router issue. Is there any way of fixing this since it gets rather annoying.
1 REPLY
Re: Repeated connection drops
12-03-2011 10:04 AM
Hi philrule,
Have a look at our troubleshhoting guide for tips on how to deal with dropped connections. If the problem still persists then raise a fault here.
Jojo
Jojo
