Remove max premium
ian007jen
Remove max premium
Could a member of plusnet staff please have a look at Question #104977888; and remove max premium.
Thanks in advance Ian
Fixes: 5
Re: Remove max premium
I've made the change, but the BT wholesale bit didn't go through as smoothly as I'd have liked. If you notice any problems tomorrow, please let me know.
 Tony T
ian007jen
Thanks Tony; I'll shout up if there are any problems.
Ian
ian007jen
Okay; there seems to be a problem.
Synch speed 1152 kbps down, 288 kbps up
OLD synch speed 6800 kbps down and about 400 kbps up
I am on an old fixed rate ADSL profile not ADSL max.
When I migrated 6 months ago, a similar thing happened and got sorted out; thanks in advance
Ian
Fixes: 5
That was the problem I was hoping wouldn't happen. I'm fixing it now.
 Tony T
Fixes: 5
Check in an hour please Smiley
 Tony T
ian007jen
Just checked.... Back to normal.
Thanks Tony  Smiley Smiley
Fixes: 5
A huge relief Smiley
 Tony T
