Remote Access
Kev99
Remote Access
I have a need to allow remote access to my laptop on a temporary basis to get some software assistance (......I understand the risks). I have been told that this facility has been disabled on my Plusnet account. Struggling to get through to Plusnet on phone to get help. Can anyone advise how I can enable remote access.
Many Thanks in advance
11 REPLIES 11
Fixes: 585
Re: Remote Access
@Kev99
By whom ? its nothing to do with your Plusnet account
What software is being proposed for remote access ?
Kev99
Re: Remote Access
My company IT department advice. They are trying to assist me with getting some software setup on my personal laptop and want to 'remote' onto my PC to sort it directly. They have told me they are unable to do this due to my providers (Plusnet) settings and that i should contact they to get this sorted. I am an effective novice on IT issues, so assumed what they have said is correct. I thought it might be something to do with router settings, but cannot see anything there on the subject.
Thanks again
Fixes: 585
Re: Remote Access
@Kev99 complete rubbish! Ask them what settings they are referring to ?
Kev99
Re: Remote Access
OK .....I will go back to the IT guys.
Many thanks for your time
Fixes: 480
Re: Remote Access
@Kev99
How long have you been a Plusnet customer? Many years ago Plusnet provided an additional server firewall that could be set to block unsolicited incoming traffic, a left over from the days of dial up connections. This is not available on accounts these days.
Kev99
Re: Remote Access
Many years with Plusnet, but I have had the router updated to a Hub Two in the past few years. I have had a look at the router firewall settings.....It is set to default...."Allow all outgoing settings and block all unsolicited incoming traffic...." Is this what you refer to ? It then advises that I will need to use 'port forwarding' features if I was to disable this. No idea what this is all about, and it does not seem right to disable the firewall anyway? But as I inferred in a previous post, my IT knowledge is very limited.
Thanks for time to respond
Fixes: 585
Re: Remote Access
@Kev99 yes that's what @Baldrick1 is referring to. You need to set it to Off, save the changes and then reboot the router.
Once you've done that, get your IT to try again, although I'm not sure what they will be able to do without some port forwarding
TBH I hadn't even considered the BB firewall as being a possibility.
There's really no reason for the BB firewall anymore, the router has a built-in one.
Re: Remote Access
@MisterW
Are you sure this is correct? looks like the Hub Two firewall is being referred to
@Kev99
There is an plusnet account based firewall which @Baldrick1 is referring to, found https://www.plus.net/member-centre/broadband/firewall probably best to set to OFF if it not already.
EDIT: can you please confirm the remote access software being used
Fixes: 585
Re: Remote Access
@Dan_the_Van
Yes, you are absolutely correct, ignore my previous post.
@Kev99 leave the router firewall at Default
That's what comes of trying to mutli-task
bighairysmile
Re: Remote Access
Observation.
Why would your employer want to install or setup s/w on your personal device?
Fixes: 387
Re: Remote Access
@bighairysmile Possibly because you have asked for assistance? I know I did many years ago, but actually took the machine into work.
