Regular wifi dropouts
Ranny
I am very close to binning this router, i just want a solid reliable connection. but am totally [-Censored-]ed off with this service.
I'm disabled, had a stroke, struggle typing and moving about with failing eye sight. Tend to rely on pc for streaming
tv. I guess i need to sort my layout. I signed up for vodaphone but had same problem so dumped them. I just want to sort this out.
19 REPLIES 19
Fixes: 334
Re: Regular wifi dropouts
@Ranny Sorry to hear of your problems, but if the Community is to help you, we need a bit more information. When you say 'regular Wi-Fi dropouts', do you mean your connection is totally failing, or just the  connection to your TV?
Which service are you on, and which router do you have?
Have you reported any of this to Plusnet?
Ranny
I have the plusnet hub 2. I tend to stream so see when it drops, although it not showing but a manuel disconect and reconnect sorts it.i use pc for streaming,
I'm on regular broadband. no not reported it yet.
Fixes: 334
OK. If I post my 'help sheet', which asks a few questions/for certain information, can you follow it - no extreme rush, but as we Community members don't have access to the Plusnet systems (obviously), we need as much info from you as possible?
Ranny
Sorry did you post it?
Fixes: 334
No, I didn't - I asked a question, but see below:
A speed test from Ooklla
For the Hub One -
For the Hub Two -
Fixes: 124
@jab1
I am thinking the event log might be of more help
EDIT: I am out from around 11 am hopefully you'll have time to check the event log?
@Ranny
You said "although it not showing but a manual disconnect and reconnect sorts it."
What are you manually disconnecting and reconnecting, the PC wifi connection or something on the Hub?
Would you able to download the Hub event log as this will hopefully give a clearer idea what is going on.
From the Hub home page, Navigate from the Home Screen to Advanced Settings > Technical Log > Event log
Click on Export, the log file will be downloaded to the Download folder, it can be attached using the paper clip below the reply window
Fixes: 334
@Dan_the_Van That was going to be my next step after examining the connection status, but as I suspect the OP may not be that technically advanced, I was taking things one step at a time.😀
Good idea though.
Fixes: 124
@jab1
The "manual disconnect and reconnect sorts it" puzzles me and make me think it could be the PC as the OP has similar issues with Vodafone.
No harm getting everything though
Fixes: 334
Agreed, @Dan_the_Van .
Ranny
i've attached a bit, hope its all there, before my a stroke i used to be proficent  with computers.
Fixes: 334
Cheers, @Ranny . That is interesting. I note that the DSL uptime is only just over two hours. I assume you don't turn the Hub off intentionally?
Could you please post the error log as @Dan_the_Van suggested?
Ranny
Thanks, quick question how do you add multiple files?
Fixes: 334
That isn't the error log we are looking for - see @Dan_the_Van 's guide in message #7
To add multi[le files, click the paper clip again once you have attached one.
Quick question for you - do you still have a land-line phone?
Ranny
No no longer have landline. Going to try to do a wsired connection
