Regular fibre drop-outs
mb1rgw
My fibre connection is dropping out exactly every 30mins. Any ideas? I've rebooted everything, and I can't think of anything that might be causing it.
mb1rgw
Re: Regular fibre drop-outs
Nobody got any thoughts? I've found various reports in the past of precisely  this happening on a variety of providers, both ADSL and FTTC, but not any solutions.
PeeGee
Do you have a "1571" phone? These can check the line for an interrupted dial tone every 30mins, starting from the end of a call, and cause such a problem (though lifting the handset should have the same effect).
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Fixes: 62
Just to confirm
Is it the modem which is dropping the connection or the router
Fixes: 77
Hi mb1rgw
I can see you spoke to us about this yesterday and we advised how to connect directly to the Openreach modem (so to rule out the router) Have you been able to give that a try?
 Adam Walker
