Regular disconnect every morning
- Re: Regular disconnect every morning
03-01-2015 7:23 AM
Lately I have had a disconnect every morning without fail, usually around 7.15am.
Does anyone know why this would happen, and is it likely to result in my line speeds being lowered - how many / how frequent must disconnects be before it affects my download speeds? Should I consider turning the router off each night?
Fortunately the connection is pretty consistent all other times, so it's a very minor thing, but I am just curious why it should do this every morning.
Keith
Keith
Message 1 of 5
(898 Views)
4 REPLIES 4
03-01-2015 9:39 AM
There is nothing obvious causing the issue from our end. Other than these drops, your connection is stable so you should be OK DLM wise.
The drops that I've seen aren't happening at exactly the same time every day, so this would seem to rule out a router time out which was my first though. Do you have anything electrical coming on at this time perhaps?
Message 2 of 5
(557 Views)
03-01-2015 9:00 PM
thanks for the reply. Yes you are right, it is sometimes just after 6am and sometimes after 7am, but always in that hour or so. As for electrical equipment, we are getting up at that time, so there could be dishwasher, washing machine, boiler, tv & other things, can they cause this to happen ? That would be interesting to know.
However it has only started happening in the last month, so I'm not sure what it might be. Anyway, I am grateful to know it is unlikely to affect my line speeds,
Cheers
Keith
Cheers
Keith
Message 3 of 5
(557 Views)
05-01-2015 9:29 AM
If it was happening a lot more often throughout the day, it would more than likely cause problems. As it is, you should be OK.
Generally, with it being about the same time everyday, I was thinking some form of REIN (electrical interference). I've seen multiple devices do this before, but if it was a television I'd expect the problem to continue whenever it's on.
Do you have any new electrical equipment recently installed? Of course, it doesn't have to be yours, I've seen peoples neighbours equipment cause problems. This is of course assuming that this is REIN and not something unrelated.
Message 4 of 5
(557 Views)
05-01-2015 10:57 AM
Keith,
If this happens often enough, it could impact your speeds.
If you would like help from the community to look at this more closely, then please post your modem stars and other information as listed in the speed issues thread. It might be beneficial to run 24x7 monitoring using RouterStats, but that's for later on.
Kevin
Kevin
Message 5 of 5
(557 Views)
