Reducing - Speed test results
- Reducing - Speed test results
- « Previous
- 1
- 2
- Next »
Re: Reducing - Speed test results
14-01-2014 7:40 PM
Well it did disconnect me - and put me onto a 15db SNR profile.
Even slower now
I tried to dis/re connect from the router webpage, and ended up needing to reboot - so that is the cause for this evenings disconnection.
EDIT
Apologies - I was reading the attenuation figure. SNR still seems to be around 10dB
Modulation : ADSL2+
Annex Mode : Annex A/L
Line State : up
Lan Tx : 551390577
Lan Rx : 333998492
ADSL Tx : 787
ADSL Rx : 631
CRC Down : 0
CRC Up : 0
FEC Down : 0
FEC Up : 0
HEC Down : 0
HEC Up : 0
SNR Up : 6.4
SNR Down : 10.3
Line Attenuation Up : 9.6
Line Attenuation Down : 15.0
Data Rate Up : 1040
Data Rate Down : 15349
Even slower now
EDIT
Modulation : ADSL2+
Line State : up
Lan Tx : 551390577
Lan Rx : 333998492
ADSL Tx : 787
ADSL Rx : 631
CRC Down : 0
CRC Up : 0
FEC Down : 0
FEC Up : 0
HEC Down : 0
HEC Up : 0
SNR Up : 6.4
SNR Down : 10.3
Data Rate Up : 1040
Message 16 of 21
(633 Views)
15-01-2014 6:51 PM
Sorry for bumping* but
Bump
* you know I'm not really.
Bump
Message 17 of 21
(633 Views)
15-01-2014 7:12 PM
Still got problems Tony?
Message 18 of 21
(633 Views)
15-01-2014 11:49 PM
Yes
I'm still on a 9+db SNR down - so whatever reset Chris thinks he gave it didn't work. (See upthread) plus this shows tonights TBB Ping graph - and speeds are still appalling at 11:45pm
Note also - I was out this evening, and Mrs TC only does light browsing on an Ipad - so the latency and packet loss is not down to activity on our connection.
Message 19 of 21
(633 Views)
16-01-2014 6:17 AM
Message 20 of 21
(633 Views)
17-01-2014 1:00 PM
Hi Chris
Any chance you can repeat the attempt to reset the SNR? I've added a ticket for this now, see ticket 79985892
Thanks.
Thanks.
Message 21 of 21
(633 Views)
- « Previous
- 1
- 2
- Next »
