Reduced stability since router reboot about 1-2 weeks ago
Oxslow
I used to be able to go weeks/months without a line drop. Now after I have rebooted the router everyday the router is going down nearly every day. I rebooted the router because I could not see certain servers for a game I play the reboot fixed that problem but caused this.
Netgear DGND3700
ADSL Link                    Downstream Upstream
Connection Speed 5491 kbps         867 kbps
Line Attenuation         49.5 db                 29.4 db
Noise Margin         2.7 db                 6.0 db
Is there anything I can do to fix this? Is it worth opening up a ticket?
Also my problem seams similar to this thread http://community.plus.net/forum/index.php/topic,110977.0.html I know I used to have interleaving turned off how do I find out if it has been switched on?
1 REPLY
Re: Reduced stability since router reboot about 1-2 weeks ago
Hi Oxslowm
I've posted a graph of your recent connection;
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13587610923948.png"/><div style="clear:both;"></div>
It seems to be stable at the moment and It looks like the drops on the graph have been caused by you.  Is the only reason you have rebooted because of not being able to see the servers for the game you're playing?
