Reduced performance
jawline
Reduced performance
I've been a customer for a couple of months, initially the line speed was very slow but after a week or so climbed to (barely) acceptable.
Over the last few weeks performance has degraded. I've gone from constantly getting > 1MB/s (8000kbits) (Roughly 1.5MB/s, usually) to now getting constantly less than 1MB/s and constant latency when browsing the internet. It's now difficult to play games if there is even a youtube video running.
It's ridiculous that I appear to be the last bloody house in this town without a fibre internet connection to start with (In the last 4 houses I've been in we've either had BT or Virgin fibre) but now the already awful ADSL performance is getting worse.
Speedtest and router statistics below
http://www.speedtest.net/my-result/5781493674
Telephone number:
Phone exchange:
EGHAM
Estimated line speed:
9Mb (This may vary between 6Mb and 11.5Mb) - Checked on 2016-11-05 13:25:05
Current line speed:
8.1 Mb
System Up Time 15:11:32
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 417512 617116 0 1236 12397 15:09:18
LAN1 Link down -- -- -- -- -- --
LAN2 Link down
LAN3 Link down
LAN4 Link down
WLAN b/g/n 300M 628740 428896 0 12668 1378 15:10:34
WLAN a/n/ac 867M 5278 1292 0 21 4 15:10:26
ADSL Link Downstream Upstream
Link Rate 9287 Kbps 1171 Kbps
Line Attenuation 28.0 dB 14.0 dB
Noise Margin 9.0 dB 6.4 dB
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Reduced performance
Testing your line isn't showing any obvious issues and it's not found any fault. Having said that, I would expect you to be connecting at a higher speed than you currently are based on the attenuation of the line.
Have you tested the phone line at all? Pick up the handset and dial 17070 running the quiet line test
 Chris Parr
 Plusnet Staff
jawline
Unfortunately I don't use the phone line and don't have a phone to test it with. Is there any alternative?
Cheers,
Blake
jawline
This has now reached a ridiculous new low, I'm barely getting 7mbps, struggling to watch videos let alone run any online games. This is awful service - the 12mbs advertised was incredibly low to start with but now the connection regularly becomes unusable. This can't be the fastest service possibly delivered to my home.
http://www.speedtest.net/my-result/5816348869
