Reduced IP Profile and Expected Speeds
- Re: Reduced IP Profile and Expected Speeds
24-08-2022 11:19 AM - edited 24-08-2022 11:21 AM
Since re-contracting in December 2021, my connection has been very stable.
Previously I was using a BT HomeHub 6 and this was OK apart from overnight reboots occurring every few days.
In January 2022 I transferred to the PN Hub 2 and all the rebooting stopped. In fact until yesterday my system has been up for 87 days.
| 02:07:46 | 28 May. DSL Link Up: Down Rate=40000kbps |
Yesterday my system rebooted and the speed was reduced.
| 12:37:37 | 23 Aug. DSL Link Up: Down Rate=36738kbps |
BT Performance Tests show that the IP Profile has reduced from 38.67 Mbps to 35.52 Mbps and measured speeds form 36.75 to 32.83 Mbps.
So my speeds are now below the expected range, can someone please investigate.
29-08-2022 1:13 PM
Hey @dejjones,
I'm really sorry to hear about the issues that you've been experiencing with the broadband speeds recently and I apologise for the delay in getting back to you. I've run a test on the line today and discovered that the current sync speeds are 38.3Mbps down and 8.8Mbps up, with no underlying fault conditions present at this time. It's been some time since you posted this topic - have the speeds on your end changed at all since then?
30-08-2022 10:41 AM
06-09-2022 7:34 PM
It is not unusual for the connection to drop some times as there a number of factors that can cause it. These are such as maintenance etc and if the drops become 3 in 24 hours or 5 in 72 hours, it would indicate a further problem.
After these drops due to the reason mentioned, it can take the speed a day or two to get back to normal levels. If it doesn't then we would have to look into to this more.
Keep an eye on it and let us know if any the above happens.
