Red lights on router
HarryBurns
Both my broadband light and router light are red. I have tried all of the fixes and tested all of the party’s but nothing has worked. Can I check if there’s a fault on the line? I’m not sure what my landline number is
4 REPLIES 4
Gel
Aspiring Champion
Fixes: 27
Re: Red lights on router
Use links below; first thing to do is to check you have a dialling tone on phone.
If that's no good report phone line fault first.
RandallFlagg
Fixes: 75
Hi @HarryBurns
As @Gel has suggested, you can report faults via the links provided - alternatively, if you can PM your account username to myself or any other staff member, we'll be happy to check this for you.
Best wishes
Dave
HarryBurns
Thanks @Gel and Dave. Dave I’ll shoot over my account details and it would be great if you could take a look.
Cheers both
RandallFlagg
Fixes: 75
Hi @HarryBurns - thanks for the PM.
I've tested your line and there's an external fault which is causing your lack of broadband connection.
I've raised this for you here on a fault ticket which contains all of the relevant details.
Best wishes
Dave
