Red light on router
- Re: Red light on router
Red light on router
19-08-2013 10:47 AM
hi this morning when I woke up, I was cleaning my room and pulled the router power out by mistake, anyway when I put it back on the lights came on normal, but my internet light was a solid red light.
So I tried to power down again same thing so pulled out the phone line same thing. but I left it for a bit then it was back to normal.
Any idea what this red light is bit worried now, someone said it may mean the router is on it's way out.
PS it a net-gear wireless router,
thanks,
thanks,
Message 1 of 6
(1,089 Views)
5 REPLIES 5
19-08-2013 10:51 AM
Can you access web pages ok? If so then probably just a glitch.
Message 2 of 6
(712 Views)
19-08-2013 11:06 AM
hi yes now I can access everything, might be as you say a glitch.
Message 3 of 6
(712 Views)
19-08-2013 11:20 AM
Is it still red?
Kelly Dorset
Ex-Broadband Service Manager
Message 4 of 6
(712 Views)
19-08-2013 11:44 AM
Quote Kelly Is it still red?
no all on green now maybe it just got upset cos I pulled out the plug by mistake and turned it on too quick.
Message 5 of 6
(712 Views)
19-08-2013 2:46 PM
It might be set to only connect on demand rather than all the time.
Check the web pages for it, connection settings.
If that was the case then until you made an outgoing connection then it wouldn't connect and stay red.
Message 6 of 6
(712 Views)
