Red light on my router internet button - but internet connection ia fine
- Red light on my router internet button - but inter...
26-09-2014 8:25 PM
My Plusnet Technicolor router recently began to display a red light instead of green for the internet connection. The light stays red regardless of whether my PC is on or off.
Thing is,there's no problem with my internet connection. Everything works well.
So what's going on? And why? And should I take any action or leave well alone?
Message 1 of 5
(1,844 Views)
4 REPLIES 4
Re: Red light on my router internet button - but internet connection ia fine
26-09-2014 9:53 PM
I vaguely remember this being a bug with some of the routers but it doesn't do anything detrimental to your connection.
If it is all working perfectly, may I suggest a bit of tape over the red light and turning a blind eye to it ?
Message 2 of 5
(1,077 Views)
26-09-2014 10:14 PM
Yup
A known glitch
If it gets annoying a disconnect/connect via the web interface can fix it
This only drops the PPP session and doesn't affect your line sync with the exchange
A known glitch
Message 3 of 5
(1,077 Views)
26-09-2014 10:32 PM
Thanks DomS and Old Jim - good to know there's nothing majorly wrong with the router or PC.
I'll try DomS's `blind eye' strategy initially but I suspect I'll end up following Old Jim's solution sooner or later.
Thanks chaps !
Thanks chaps !
Message 4 of 5
(1,077 Views)
26-09-2014 10:54 PM
I turn all my leds off!
[tt]
Turn Off LED Lights
Command
system qual led value=alloff Turn all LED's off
saveall Make permanent
Undo -- Enable LED lights
Command
system qual led value=unlock Enable LED's
saveall Make permanent[/tt]
http://npr.me.uk/telnet.html
[tt]
Turn Off LED Lights
Command
Command
Message 5 of 5
(1,077 Views)
