Red light and no internet conection
AlexBodrov
GM
Have some issues with my router and connection. if I understand correctly I should already have the Internet but it is for some reason missing. could you check what's wrong?
Fixes: 25
Re: Red light and no internet conection
Hi Alex,
A warm welcome to the forums.
When were you told that your account would be active?
Did you connect the router before then?
Have you tried a factory reset?
Have you logged on to the router to see if the account details are correct?
Is there a dial tone on your phone line?
AlexBodrov
When were you told that your account would be active? - 2nd of March
Did you connect the router before then? - No,I didn’t.
Have you tried a factory reset? Yes, I did.
Have you logged on to the router to see if the account details are correct? - I don’t exactly understand what you mean. I tried to log on the router with admin psswd
Is there a dial tone on your phone line? -No
AlexBodrov
I can’t check it I don’t have a phone Smiley
Fixes: 25
Ohhh!!  That is an essential diagnostic tool! Thumbs Up
Without a dial tone, this becomes a phone problem, not a broadband problem.
See the user guide which provides information on logging in and manually setting the user name.
Also look at the line stats page to see if line speeds are reported.
Fixes: 204
@AlexBodrov Apologies for the delayed response.
It looks like the order was pushed back to the 8th due to the weather.
Apologies for any inconvenience caused.
 Matthew Wheeler
