Red light and flashing b symbol on router
Rags
I'm sure it's been asked about thousands of times on here but this we've got no service (it's been out for over an hour now) - red light and flashing b on router. Desperately trying to work from home and have limited data - can someone please help asap!
8 REPLIES 8
Fixes: 334
Re: Red light and flashing b symbol on router
@Rags Have you got service on your land line?
Rags
Hiya, yep the landline seems to be working ok
Tags (1)
Fixes: 334
OK - in that case report a broadband fault via: https://www.plus.net/help/report-a-problem/broadband/
Rags
Hmm it tells me that page doesn't exist
Fixes: 334
Sorry - see edit.
Rags
Many thanks for your help! I've tried sending them a text 🤞
Fixes: 457
Moderators Note
This topic has been moved from Full Fibre to Broadband
Fixes: 236
If the router's light is red, that suggests it needs a factory reset - see How to set up your Plusnet Hub Two router | Help | Plusnet
