Red internet light
sarahv67
Red internet light
Accidently turned off the router , Technicolor router, red internet light came on and now have no internet.  Reset router, red light now green, still no internet
Fixes: 136
Re: Red internet light
Can you try resetting it again one more time?
 Matthew Wheeler
sarahv67
Hi Matthew. That has worked,  thank you so much.  We have had more occasions of buffering when streaming recently.  What would be the best way to check this please?
Thanks again
Fixes: 136
Glad to hear it.
Is the buffering over a wired or wireless connection?
 Matthew Wheeler
sarahv67
Wireless connection. On the iPad. Catchup TV normally, and Amazon Prime.
MrSilver
Fixes: 9
Are you in the same room when it happens?
If you go to fast.com on the ipad wheen you ge tthe buffering what speed does it report? Or screenshot the graph on http://speedof.me ?
