Red internet light new customer
Babygirl1985
I was due to go live with plus net yesterday however, all the lights are green apart from the internet one which is red. I have tried to reset it, i have logged onto my router in a browser and nothing works. I really need internet to be working for my college course and never issues with previous suppliers!
5 REPLIES 5
Gel
Aspiring Champion
Fixes: 27
Re: Red internet light new customer
HarryB
Fixes: 256
Hi @Babygirl1985, I'm sorry to hear you're experiencing connection issues following the completion of your orders.
I understand you've already been sent some steps to manually update your router config as it appears to be a problem authenticating.
Can you run through our troubleshooting guides here: https://www.plus.net/help/broadband/connection-troubleshooting/
It may also be worth connecting to the test socket to try and rule out issues caused by internal wiring. More information on this can be found here: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
If you continue to experience problems after this, please report the issue here and let us know when you've completed it: https://faults.plus.net
We'll then be able to get this raised with our suppliers for further investigation for you.
Thanks.
 Harry Beesley
Babygirl1985
I’ve done all this and still not working!! So frustrating
JOLO
Fixes: 77
@Babygirl1985
I've raised a fault on your service to try and get this resolved for you.
Babygirl1985
Ok great as tried everything suggested and I really need internet will struggle without it.. already regretting changing my supplier.. it was easy with them! X
