Red b on router
- Red b on router
Red b on router
20-08-2020 9:35 AM
Unable to connect to the internet today. Was working fine last night and this morning won't connect. I have restarted the hub, when I try to connect to my SSID it takes me to a troubleshooting page and I log in to my hub and it asks me to put iny username and password, when I do this is says you aren't connected. When I click reset I get the same message. I have reset the hub and nothing works. I have changed the filter and my phone line works as I can make calls. Tried calling plusnet support but get an automated message saying to try later or tomorrow.
Message 1 of 2
(560 Views)
1 REPLY 1
Re: Red b on router
20-08-2020 9:10 PM
Hi, someone else had a similar problem here:
Good luck
Message 2 of 2
(522 Views)
