Recovering from Line Fault
- Recovering from Line Fault
29-11-2011 8:15 PM
Anything I can do or do I just wait?
Re: Recovering from Line Fault
29-11-2011 8:17 PM
Can you post the result of a BT speed test for me so I can see what your current profile is?
Jojo
29-11-2011 8:26 PM
BT speedtester saying:
Download max achievable speed is: 15966Kbps
> Download speedachieved during the test was - 14533 Kbps
For your connection, the acceptable range of speedsis 12000-15966 Kbps .
Additional Information:
IP Profile for your line is -15966 Kbps
Upload max achievable speed is: 10000
>Upload speed achieved during the test was - 2142 Kbps
Upstream Rate IP profile on your line is - 10000 Kbps
So that's looking like that it hasn't moved at all since the engineer has left
29-11-2011 8:29 PM
I would have expected the engineer to reset the profile while he was there. Maybe he did but it hasn't taken effect yet. I'll ask one of our fibre guys to take a look in the morning and see what they think.
Jojo
29-11-2011 8:34 PM
[Moderator's note by Dick (Strat): Full quote of preceding post removed, as per Forum Rules ]
Too late. I'd already removed it
29-11-2011 8:36 PM
29-11-2011 8:37 PM
30-11-2011 9:38 AM
The suppliers systems we use to check line stats is temporarily unavailable, so I won't be able to do anything until later. If you could run a BT speed test before then just to make sure the profile still hasn't changed that might help.
Jojo
30-11-2011 10:07 AM
30-11-2011 10:10 AM
30-11-2011 10:13 AM
30-11-2011 7:13 PM
Would turning the modem off and on be worth a try to see if it picks up a new profile (assuming there is one)?
30-11-2011 10:22 PM
> Download speedachieved during the test was - 13245 Kbps
For your connection, the acceptable range of speedsis 12000-14519 Kbps .
IP Profile for your line is -14519 Kbps
>Upload speed achieved during the test was - 1568 Kbps
01-12-2011 1:35 PM
01-12-2011 2:46 PM
