Reconfigure fibre router for ADSL
quackers
Re: Reconfigure fibre router for ADSL
OK thanks , I'll try wireless, the factory default password is the one printed on the case I guess so that should be OK and like you say, not much to lose !
mattturner
Hi Quackers,
I'm afraid the update process won't work on Wireless (at least I'm 99% sure it won't). The router boots up into a low firmware mode before running the update process, I don't think this mode has wifi support.
But you should try it and find out, I'm 100% sure that it won't break your router, it will simply fail to start.
Matt
NorthEasterner
Can you not send the router back to Plusnet and swap it for an ADSL one? that would simply make the process easier?
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up Thumbs_Up
Fixes: 400
Hadn't thought about that. The upgrade runs a TFTP server on the PC and then reboots the router to a basic tftp client. As Matt says, that probably doesn't support wifi...
NorthEasterner
Whats wrong using an ethernet connection?
Fixes: 400
The ethernet port is not functioning on my laptop.
w23
Fixes: 4
Can't Plusnet flash the router remotely in this case?
Call me 'w23'
Fixes: 400
I have a Technicolor TG582n which has been set up as a fibre router, how can I reconfigure it for ADSL ?
Catch 22 I suspect...
w23
Fixes: 4
Ah!
Maybe worth getting something like one of these: https://www.google.co.uk/search?q=usb+ethernet&ie=utf-8&oe=utf-8&aq=t&rls=Palemoon:en-US:official&cl...
Call me 'w23'
