Reconfigure fibre router for ADSL
quackers
I have a Technicolor TG582n which has been set up as a fibre router, how can I reconfigure it for ADSL ?
23 REPLIES 23
NorthEasterner
Re: Reconfigure fibre router for ADSL
Does it not detect automatically?
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up Thumbs_Up
quackers
Apparently not, I attached the DSL cable but neither broadband nor internet light comes on. DSL cable works fine with another router so there is a definitely a signal present.
Mattz0r
I believe there is a firmware upgrade from an ADSL 582n to become an FTTC 582n, but not the other way round!
Happy to have a look on your account and see if I can arrange for an ADSL one to be sent out for you.
Regards,
Matt
quackers
Thank you Matt, what would be the charge for that ?
Fixes: 385
I thought the latest testing firmware had a facility to switch to ADSL http://community.plus.net/forum/index.php/topic,114824.msg988842.html#msg988842
Mattz0r
I stand corrected!
Thanks MisterW, been looking for that thread for a while.
Fixes: 385
I seem to recall seeing somewhere that you use the setup wizard ( on 10.2.5.2 ) to select ADSL mode but I can't find the information now...
quackers
Thank you . How can I install this latest firmware ?
Fixes: 385
It's all in the link http://products.plus-payh.co.uk/firmware/ referred to in the thread I linked to.
quackers
The link you sent shows five different options for the 582n, I suppose I want one of the two at the bottom of the list since they refer to fibre routers. How can I tell which one to choose ? I clicked on one and it was talking about Thomson 585 ? Sorry , some people are more tech savvy than others , I expect its obvious what's going on only not to me I'm afraid
NorthEasterner
this link http://products.plus-payh.co.uk/firmware/tg582n/plusnet/8.4.4.J/PN%20TG582n%20R844J%20+USB%20BW.bin
It is for the router with USB port to reconfigure to ADSL
Fixes: 385
You want the last one in the list, the one that says version 10.2.5.2.
No problem. Yes, the first 2 links regarding the upgrade tool and the instructions do refer to the TG585. The upgrade tool and procedure are common to the older TG585 and the TG582n. Hope that helps make thinks a little clearer.
quackers
Yes thank you it does.
But looking at the instructions it says do not attempt upgrade via wireless connection. Is that a complete no-no or just less likely to succeed ? The ethernet port is not functioning on my laptop. How about USB connection , would that do ? As I'm a Windows 7 user I have downloaded the version the link advises for that OS.
Fixes: 385
The problem with wireless is that 1) it can be unreliable and 2) when the router reboots after the f/w upgrade, it will be back to factory defaults. If you've changed the SSID/password then you wont be able to connect again with the old details. Hence it's really not recommended but since the router is not useful to you as it is, what can you lose ?
There is no facility to connect a PC/laptop via USB. The USB connection on the TG582n is for storage(USB disk/memory stick) or 3g dongle only
