Recommendations for wireless access point?
- Recommendations for wireless access point?
15-06-2016 3:36 PM
As the titles says, any recommendations for a wireless access point using standard broadband? I am using a TP Link D7 and will be using a wired connection to the wireless point. Price - anything up to £50.
Message 1 of 2
(572 Views)
1 REPLY 1
Re: Recommendations for wireless access point?
15-06-2016 3:44 PM
Personally I'd suggest looking into ubiquiti if you want a dedicated access point. a bit higher price than your budget(around £60-70 for the basic ones) but such great devices.
