Recommend me replacement Router?
poolesr
On Fibre 80/20 with a Techicolour TG582n router.
I'm getting fed up of having reboot it everyday as it drops out and I loose any connectivity (Wired or wireless)
Never had issues with my old SKY or replacement Linksys router when I was on ADSL2
Who's upgraded their router from the STD plusnet one ?
Si
poolesr
Re: Recommend me replacement Router?
Sorry found the vdsl thread. (didn't know the terminology to search for) Smiley
Fixes: 22
Hi Poolesr,
Welcome to the forums.
What makes you convinced that the problem is the router?  What lights are on / off when you encounter the condition on both the router and the modem?  What does the router log show?  What are the exact symptoms?
Is this the fibre version of the router and what is the version of the firmware?
