Recently upgraded / slow speeds
moggies2
We've recently renewed and upgraded to fibre unlimited. It's been over 14 days now and our speed is hitting below average download. I've done a line test and there's no noise and reset. Also started using a new hub 2 router from Plusnet
Is it possible I'm on a different profile, or that the DLM needs a reset?
Cheers
4 REPLIES 4
Legend
Fixes: 290
Re: Recently upgraded / slow speeds
@moggies2 Hopefully one of the Help Team will pick this up but:
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
willcutforth
Fixes: 113
Hey there again @moggies2
I've just checked the line and there is an Earth contact on there so I have raised it to Openreach. It should be fixed within a few days. I will check back on Tuesday for you.
 Will Cutforth
moggies2
Ok, so maybe that would explain the slow speeds and my hub 2 router saying I should be getting better speeds.
Do I have to do anything when Openreach look into this? As in do they need access to the property?
willcutforth
Fixes: 113
At the moment it is all external but if they need to come in, I have given them your number to call you Smiley
 Will Cutforth
