Recent upgrade before fibre optic came
- Recent upgrade before fibre optic came
12-10-2013 10:01 PM
Re: Recent upgrade before fibre optic came
12-10-2013 11:09 PM
13-10-2013 2:03 PM
13-10-2013 2:17 PM
13-10-2013 2:31 PM
13-10-2013 5:52 PM
13-10-2013 6:24 PM
13-10-2013 6:27 PM
13-10-2013 6:37 PM
The answer will tell you if or not you are on the same cabinet and what (different) services are available to both of you.
13-10-2013 6:40 PM
I'm sure a forum staff member will pick this up on Monday and check fibre availability using your customer details.
14-10-2013 11:02 AM
I'm afraid it looks like there isn't any fibre available on your line, as per the dslchecker link posted by Jaggies above. It's likely that your neighbour is connected to either a different cabinet or an entirely different exchange - the samknows link purleigh posted above will tell you which exchange you're connected to.
