Recent speed drop.
- Recent speed drop.
- « Previous
- 1
- 2
- Next »
Re: Recent speed drop.
07-12-2014 4:40 PM
Router is a TG585v7. Normally connected to a hard wired extension socket 3 feet long through a wall. Two wires. No bell wire. Just connected direct to master socket with front removed. Speed is the same at 2.5 mb. Tried 3 filters with no change.
I tested it a few times. The upload test seemed to take a long time to complete. 25+ seconds?. No idea if this is relevant.
Message 16 of 22
(392 Views)
07-12-2014 4:58 PM
Unfortunately, trying so many different things in a such a short time is a bad idea because frequent disconnections make is very likely the DLM system will automatically increase the target SNRM which will decrease the speed. I strongly advise against causing any more disconnections for at least 24 hours.
A speed test won't show any immediate difference, because it can take a few days for the IP profile increase to reach Plusnet. But any differences in line speed are visible in the DSL stats.
Message 17 of 22
(392 Views)
11-12-2014 8:39 AM
I've left it all connected since the seventh but the speed is still 2.1mb download and 500kb upload. Should it have reset by now.
DSL Connection
Link Information
Uptime: 1 day, 22:45:45
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 895 / 2,547
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 228.00
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 28.0 / 47.5
SN Margin (Up/Down) [dB]: 5.0 / 8.0
Loss of Framing (Local/Remote): 66 / 0
Loss of Signal (Local/Remote): 6 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 348 / 0
FEC Errors (Up/Down): NA / 0
CRC Errors (Up/Down): NA / 12,684
HEC Errors (Up/Down): 0 / 10,780
DSL Connection
Link Information
Message 18 of 22
(392 Views)
11-12-2014 9:57 AM
2.2Mb is the correct profile for the current sync speed, which is not good. You had several drops in connection which could be DLM testing different conditions as the line is in training until about the 16th. But as ejs sad the speed is not good.
Can you hear/have you heard any crackling or other noises on the line when using the phone? Have you had any problems with incoming or outgoing calls? A faulty line could be the cause of the issues.
Message 19 of 22
(392 Views)
11-12-2014 10:14 AM
Looking at the history of profiles coming through from BT, it does seem that your line has fluctuated a lot since March this year.
The line, in the main, looks stable. There has been drops both recent and a few days back in October and November but it's difficult to tell if these are tests as many of them are close together.
It may be that your speeds can be increased (though I can't guarantee this), but that would most likely involve an engineer visit. If you want us to do that, please raise via faults.plus.net and post the ticket number here so that I can arrange something for you.
Tony
Tony
Message 20 of 22
(392 Views)
16-12-2014 2:20 PM
The speed is still the same. If there is no charge for the visit etc I would be keen for this to happen. I'm not sure how to raise a fault but will try and return if unsuccessful.
Message 21 of 22
(392 Views)
16-12-2014 2:22 PM
You should just need to follow the steps at https://faults.plus.net and once you've answered all the questions this will report the fault to us for testing.
Message 22 of 22
(392 Views)
- « Previous
- 1
- 2
- Next »
