Recent peak-time speed problems (Nov 08) - Please read this!
zubel
There have been many reports of *severe* speed problems during peak times across packages and gateways recently.  I would like to collate some information on them in the hope that Plusnet will be able to use this information to investigate common threads.
So, if you are having problems with peak-time speeds, can I ask you to read the following, and submit a reply answering as many of the questions as possible.
1.  Your product type
This information can be found here. For example, mine is:
"PlusNet Broadband Your Way Pro with included 15GB bandwidth"
2.  Your current usage from the VMBU
The "View My Boradband Usage" tool will show you exactly how much you have used in the current billing month.  You can access the VMBU tool here.  Please post your current usage similar to the following:
Paid-for usage  11.22GB  8am - Midnight
Paid-for allowance: Up-to 15GB 8am - Midnight
Free usage: 55.62GB Midnight - 8am
Total usage: 66.84GB
3.  Your IP Profile, as reported by Plusnet
You can access this information here.  Please copy/paste the information like this:
"Your current broadband speed is 7150 Kbps"
4.  Information from the BT Speedtester
Please run the BT Speedtester and post the results in the following format:
Your DSL connection rate: 8128 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    IP profile for your line is - 7150 kbps
    Actual IP throughput achieved during the test was - 6252 kbps
5.  A Speedtest from an external testing site.
Please try to do an external speedtest.  I recommend using This one.  Post the results including the date and time of the speedtest.  If there are particular times when you connection is "bad", please try to post a comparative speedtest from when your connection is "good".
6.  Your gateway
If you visit this link and please post the results:
"You are currently connected to the "City Lifeline, Juniper 8" gateway. This gateway is sometimes known as pcl-ag01."
7.  Your exchange status
Go to the Exchange checker and post the "VP Status" of your exchange:
"VP capacity at this exchange is currently showing as Green."
8.  Any other information
Please include any other information that you think may be pertinent.  Please keep it brief and to the point.  If we can collate together as much information as possible then it should assist Plusnet in identifying a common cause and resolving the issue once and for all.
I have included a template post below, which you can quote from and then fill in.
Please note that any posts that are not in this format are likely to be split off, or removed without warning
B.
141 REPLIES 141
zubel
Re: Recent peak-time speed problems - Please read this!
6.  Your gateway
zubel
EXAMPLE POST:
6.  Your gateway
"Speeds are slow from exactly 4.00pm every day until 4.07pm, then speeds seem to return to normal."
jelv
Fixes: 10
Barry, Can I suggest that external speed test results should include the date time the test was run and if they are seeing slowdowns at particular times of the day results from when it is both good and bad should be posted as a comparison.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
pierre_pierre
Broadband Your Way 2
Key: Peak usage Paid-for usage 2.57GB 8am - Midnight
Key: Peak usage Free usage: 133.11MB Midnight - 8am
  Total usage: 2.7GB
7150
9 Nov
Test1 comprises of Best Effort Test:  -provides background information.
    Actual IP throughput achieved during the test was - 2347 kbps
11th
    Actual IP throughput achieved during the test was - 5694 kbps
Today 08:05  7329 kbps (916kB/s)  381 kbps (47.6kB/s)
Yesterday 17:56 6313 kbps (789kB/s) 377 kbps (47.1kB/s)
Yesterday 17:18 3366 kbps (421kB/s) 351 kbps (43.9kB/s)
Yesterday 16:35 2619 kbps (327kB/s) 382 kbps (47.8kB/s)
6.  Your gateway
You are currently connected to the "Telehouse North, Juniper 6" gateway. This gateway is sometimes known as thn-ag1.
green
OK in Morning and after about 2200Hrs
Rough in afternoon.
on the myspeedtest the speed needle is very jumpy  goes from say 2400 - 4000 and back down again
weekend speed test 5/6th Nov below
MickKi
Re: Recent peak-time speed problems (Nov 08) - Please read this!
Paid-for usage 1.03GB 8am - Midnight
Free usage: 8.24GB Midnight - 8am
Total usage: 9.27GB
"Your current broadband speed is 8000 Kbps"  <-- please leave this as is (I'm happy with it and it is not related to the fault)
Your DSL connection rate: 7456 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    IP profile for your line is - 6500 kbps
    Actual IP throughput achieved during the test was - 4123 kbps  (@21:10 tonight)
I was well surprised by this 4123 kbps!  Over the last few days it would be a miracle to get anything above 2150 or so.
Note: I've had the same sync rate and IP profile for the last 50 days.
mybroadbandspeed.co.uk
Date	            Download Speed	        Upload Speed
Today 20:20     1885 kbps (236kB/s) 339 kbps (42.4kB/s)
Yesterday 21:04 1162 kbps (145kB/s) 339 kbps (42.4kB/s)<--MSWindows patch Tuesday
Monday 20:13   1311 kbps (164kB/s) 341 kbps (42.6kB/s)
Normal evening speeds:
6.  Your gateway
You are currently connected to the "Telehouse North, Juniper 2" gateway. This gateway is sometimes known as ptn-ag2.
"VP capacity at this exchange is currently showing as Green."  (It's always been green - I live out in the sticks).
"Speeds are slow from around 6:45pm every day until after 22:00-23.30pm depending on the day, then speeds seem to return to normal."  Late at night and early in the morning I get speeds of c. 6214 kps which corresponds with my 6500 IP profile.
zoomclub
Quote from: Barry
PlusNet Broadband Your Way Option 1 with included 6GB bandwidth
  Paid-for usage  2.36GB  8am - Midnight
  Paid-for allowance: Up-to 6GB 8am - Midnight
Key: Peak usage Free usage: 0KB  Midnight - 8am
  Total usage: 2.36GB
Your current broadband speed is 7000 Kbps
Your DSL connection rate: 8096 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    IP profile for your line is - 7000 kbps
    Actual IP throughput achieved during the test was - 1181 kbps
6.  Your gateway
You are currently connected to the "Telehouse East, Juniper 4" gateway. This gateway is sometimes known as pte-ag2.
Really pleased to get 6Mbps d/l while checking in the afternoon - 2pm, but then after 6pm roughly speeds drop fairly dramatically - checking every 20 - 30 mins shows a drop down to 1.7Mbps by 9.30pm. Having said that, last night - 11/11/08 speed was down to 890kbps by 8pm!
Hope this helps and Thanks for the template.
paulh
PlusNet Broadband Plus up to 8Mb
Peak usage: 1.45GB 4pm - Midnight
Off-peak usage: 1.53GB Midnight - 4pm
Total usage: 2.99GB
Your current broadband speed is 6500 Kbps
"Good(ish)": Weds 12/11/08 17:50
Your DSL connection rate: 7616 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
Actual IP throughput achieved during the test was - 4160 kbps
"Bad": Mon 10/11/2008 19:00
Actual IP throughput achieved during the test was - 634 kbps
"Good: mybroadbandspeed.co.uk 11/11/08 07:16  5910 kbps (739kB/s) 346 kbps (43.3kB/s)
"Bad":  mybroadbandspeed.co.uk 11/11/08 18:32  821 kbps (103kB/s) 350 kbps (43.8kB/s)
6.  Your gateway
You are currently connected to the "City Lifeline, Juniper 9" gateway. This gateway is sometimes known as pcl-ag02.
Browsing experience laggy, stuttery, poor.
pierre_pierre
in addition to my report - #4
It seems much better tonight, graph of last three days
Cartzim
In response to Barry's template (thanks for including the links to the various sources of info):
1/ PlusNet Broadband Pay As You Go with included 2GB bandwidth
2/  Paid-for usage 224.76MB  8am - Midnight
  Paid-for allowance: Up-to 2GB  8am - Midnight
Free usage: 29.07MB  Midnight - 8am
  Total usage: 253.83MB
3/ Your current broadband speed is 3000 Kbps (Note it was 3500 late last night and I'm only 1.7km from the exchange.....))
4/ 'The system is currently busy. Please try again shortly, however if this problem persists, raise the issue with your service provider' Exactly!
Then at 21:57 today 12/11/08
    Your DSL connection rate: 3776 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    IP profile for your line is - 3000 kbps
    Actual IP throughput achieved during the test was - 733 kbps
i.e pretty poor!
5/ http://www.mybroadbandspeed.co.uk/
Today 22:00 715 kbps (89.4kB/s) 372 kbps (46.5kB/s)
Yesterday 22:29 672 kbps (84kB/s) 236 kbps (29.5kB/s)
i.e pretty poor!
6/ "You are currently connected to the "unknown" gateway"
?????????????????????????Huh
2nd attempt gave me You are currently connected to the "Telehouse North, Juniper 1" gateway. This gateway is sometimes known as ptn-ag1.
7/ VP capacity at this exchange (Milton Keynes) is currently showing as Green. Record last updated: 20 Oct 08
Any other info
A "good report"
16/08/2008 19.39 Line Rate 4160 Kbps 448 Kbps Sync rate 3500     IP profile for your line is - 3500
Attainable Line Rate 4576 Kbps 1036 Kbps     DSL connection rate:  4160
Noise Margin 6.1 dB 20.0 dB 448
Line Attenuation 50.0 dB 29.0 dB     Actual IPthroughput achieved during the test was - 2710
Output Power 11.9 dBm 19.1 dBm
I'd be pleased to know why this has ground to a halt. Contention? I thought I was paying extra for less contention. Maybe not, and if so where's it come from?
Cheers,
cjc
Chris
Legend
Fixes: 169
On the whole were speeds better or worse last night? We made some changes to the ellacoyas to try to alleviate some of the issues and are interested if they have made a difference.
@Cartzim,
There were still some gold packets dropped last night, however this was nowhere near the level of the previous night. Are you able to try again tonight, if you see the same speeds try rebooting your modem/router and test again.
As a general note, we've seen a massive increase in gold traffic during October which is in part causing some backlash, we've got some more tweaking and work to do on the profiling and will get the speeds back to normal asap.
jelv
Fixes: 10
How much of a drop off would you expect to see on PAYG at 9:15 last night on ptn-ag2 (4789) compared with just now (6713)? Is that acceptable or do I need to do the full report (in which case I'll edit this post).
Chris
Legend
Fixes: 169
TBH jelv that's very likely just normal contention, it tends to be slightly lower on the days just after a patch Tuesday.
jelv
Fixes: 10
It's one reason I normally stick to RIN - I don't then see those slowdowns!
techguy
I'll do some proper testing when I'm off again but would it also be useful to note what you were actually doing? e.g. browsing when you noticed the slowdown? (I shall read the full definitions of traffic classifications as I haven't done yet)
Does it just seem to be Gold class traffic then?
