Reccurent disconnections - advice sort
- Reccurent disconnections - advice sort
01-01-2008 4:09 PM
Hello all and happy new year.
I have a Plusnet standard BT branded wireless router and have never had any problems.
Within the last 3 or 4 days, my synch light goes from green to flashing amber, before going back to green after 30 secs or so. To me this means its losing its synchronisation. I have replaced the splitter/filter and that has not fixed the problem.
I never lose connection to the router, just to the internet which is becoming a pain in the neck. All Plusnet self help tests have not shown there to be any problems.
I have gone in to my router and discovered the following stats;
since reset Current 24hrs
ATM Cell Header Errors: 220 147
ATM Loss of Cell Delineation: 0 0
DSL Link Retrains: 3 2
DSL Training Errors: 177 28
DSL Training Timeouts: 0 0
DSL Loss of Framing Failures: 6 4
DSL Loss of Signal Failures: 4 4
DSL Loss of Power Failures: 0 0
DSL Loss of Margin Failures: 4 4
DSL Cumulat Err Seconds: 12 4
DSL Severely Errored Seconds: 6 4
DSL Corrected Blocks: 545 151
DSL Uncorrected Blocks: 219 144
ISP Connection Establishment: 23 23
I have raised a ticket with Plusnet, but would appreciate any advice.
Many thanks
Matt
Many thanks
Matt
Message 1 of 2
(887 Views)
1 REPLY 1
Re: Reccurent disconnections - advice sort
02-01-2008 11:08 AM
Hi Matt,
It does indeed sound like your router is dropping synchronisation with the exchange. Can you possibly try the following for me?
- Try using a different filter
- Ensure that you are connecting directly into your master socket via a filter
- Try using a different modem or router if this is at all possible.
Failing this helping, we can subsequently raise a fault to BT on yuour behalf and get them to investigate your line.
Message 2 of 2
(262 Views)
