Reccomended routers please
davewood6196
Hello everybody,
I have been blessed with the standard Plusnet TG582n router that when plugged into the openreach machine roughly halves the MBPS, I am now on the third router with no changes, Can anybody recommend a good router or how to set this one up more efficiently?
Dave
Fixes: 62
Re: Reccomended routers please
how are you checking the speed and are you doing it via wires or wireless
I've been using the Asus RT-N56U for the past 12 months & am absolutely delighted with both its performance & serviceability..
Hi, sorry to hear that, not sure what you mean by halving your MBPS though? If you could paste the stats from the router in here along with a speed test result (ideally from http://www.speedtester.bt.com) we'll be able to advise further.
EDIT: Apologies, you won't be able to get the router stats as it's a fibre line, sorry about that. However if you could do the speed test it'd be very useful, thanks.
