Rebooting?
thehentons
Rebooting?
Hello
Im just making sure that if i do reboot my router that my ip profile won't drop as they could see it as an intermittent connection?
thanks,
Fixes: 60
Re: Rebooting?
An intermittent connection doesn't directly affect the ipProfile as that is governed entirely by the lowest sync speed.
However rebooting too frequently - such as several times in a short time period - can be seen as instability and can result in a higher default noise margin which will lower the sync speed and hence the ipProfile.
Rebooting occasionaly - once or twice per day for example should have no effect
Just don't do it after dark if you can possibly help it as that will be when you get the lowest sync speed
thehentons
Re: Rebooting?
Thanks for the quick and detailed reply  Smiley
i will wait till the morning then before i try a reboot and see if i see any changes or improvements in my speed.
Thanks  Smiley
pierre_pierre
Re: Rebooting?
and Jim should have said welcome to the friendly forums
Fixes: 60
Re: Rebooting?
who said I was friendly  Grin - that is probably against the moderating guidelines  Embarrassed Embarrassed  Lips are sealed
