Reason for an "event" just after 2AM 8 April?
- Re: Reason for an "event" just after 2AM 8 April?
08-04-2014 6:24 AM
My apologies if this is a silly question but I'm curious as to the possible reason for the event at just after 2 AM this morning. My latency has dropped & my gateway has changed from Pcl-ag01 to Ptn-ag02. I was asleep at the time so it's nothing to do with me!
Thanks in advance for your time in answering.
Message 1 of 8
(1,377 Views)
7 REPLIES 7
08-04-2014 9:21 AM
Does you area code come up for any maintenance here http://status.zen.co.uk/broadband/ ?
Is more than likely some kind of planned work - a lot of BT maintenance is at 2:00 am
Message 2 of 8
(893 Views)
08-04-2014 9:27 AM
It's very likely that it was caused by BT Maintenance, we've got quite a lot going on during this week.
Message 3 of 8
(893 Views)
08-04-2014 10:20 AM
Quote It's very likely that it was caused by BT Maintenance
I didn't see anything in the email re BT maintenance covering 01425.
Message 4 of 8
(893 Views)
08-04-2014 10:31 AM
There's some planned for the 9th covering 01425 because it's also covering my town to 01590. But think yourself lucky that latency has dropped
Mines done the opposite and increased, for no reason!
Message 5 of 8
(893 Views)
08-04-2014 10:45 AM
I believe the drop may have been in reference to: PW237010
Although your dial code may not have been listed, one of the parent exchanges that your exchange relies on may have had some maintenance work carried out on it.
Message 6 of 8
(893 Views)
08-04-2014 2:28 PM
Thanks Chris, just curious. As always it's also knocked a couple of Megs off my D/L speed but hopefully that will recover over time?
Message 7 of 8
(893 Views)
08-04-2014 3:02 PM
I'm sure it will, but if you could keep an eye on it, that'd be great. Let me know if your line doesn't recover - let me know.
Message 8 of 8
(893 Views)
