Really slow upload speed
davegraham2013
I'm suffering from really slow upload speeds - currently 0.156 mb/s - pretty useless for my needs.
I've monitored this over my first 2 weeks with Plus, and it has remained constant.
Is this normal? - before on Talk Talk it was at least over 1 meg.
Re: Really slow upload speed
I've checked your line and your upload it currently set to 448Kbps, I've placed a modify order to change this to uncapped and this will complete tomorrow.
Are you currently using a wired or wireless connection as your upload speed seems to be short of what your sync speed is?
Chris
davegraham2013
Quote from: chrispurvey
Chris
Thanks Chris,
Currently using a wired connection.
Let us know how you get on tomorrow when the modify order has completed.
davegraham2013
That's much better, thanks
And thanks for sorting it so quickly.
