Really slow download and upload speed
- Really slow download and upload speed
05-08-2018 9:13 PM
Re: Really slow download and upload speed
05-08-2018 9:40 PM
Welcome to the forum.
What speed should you be getting, with standard broadband? This depends on how far you are from your local exchange. What does it say if you put your number in here. https://www.dslchecker.bt.com/?
If the line is only capable of slow speeds the above link will also advise of alternatives available.
05-08-2018 10:28 PM
thats the reason im leaving, plusnet promise the earth and give you the slowest possible speed, just switched and getting fiber for £5 cheaper than standard broadband with plusnet, you really get nothing from plusnet for being a loyal customer
06-08-2018 2:08 PM
Hi @Mdaly0101 and thanks for getting in touch.
Some sound advice from @Baldrick1 there - ascertain what your line is capable of using www.dslchecker.bt.com and then run a wired speed test to see how this stacks up.
Wifi troubleshooting can be accessed here if you find that your wired speed is good.
Let us know how you get on.
Best wishes,
Dave
