Really really slow....
- Really really slow....
02-09-2007 11:44 AM
Hi there, i'm syncing at about 3700 (which seems to be about normal for me) but my speed is just so so slow, speed test shows:
is this a network or exchange problem?
as well as download speeds, there seems to be very high latency, i read a thread earlier about in increase in dropped packets on the network - is the effects of this basically what i'm seeing?
Message 1 of 8
(2,060 Views)
7 REPLIES 7
Re: Really really slow....
02-09-2007 12:00 PM
Hi PJ,
Here is the results of the test:
Results Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 3000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 3712 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 808 kbps
sadly, it doesn't seem to test latency, but my connection feels really 'laggy' today.
Message 2 of 8
(790 Views)
02-09-2007 12:20 PM
Those results do show a faulty line. I'd say it'll be well worth raising a fault - this can be done at http://faults.plus.net - as the speed test results should be picked up automatically. If not, and the ticket is sent back to yourself (there are several threads on here showing this text - I believe it's along the lines of 'speed tests show your current speed as: none found) just paste in the results of your test as above and we'll continue the investigation.
Hope this helps, sorry about the hassle.
Message 3 of 8
(790 Views)
02-09-2007 1:42 PM
Would also be worth doing things like :-
- If you have a Wireless router, ensuring it is secured and that nobody else is using your connection
- Making sure you don't have any spyware / viruses on your PC(s) hogging the connection or any open programs which are hammering your line (have you checked your usage to see if it shows an increase in usage?)
- Trying the MTU / RWIN tweaks following advice here : http://www.kitz.co.uk/adsl/MTU2.htm
Message 4 of 8
(790 Views)
02-09-2007 2:13 PM
just out of interest, i did the bt speed test again after going out for a while, and i'm now getting:
Actual IP throughput achieved during the test was - 2425 kbps
my connection is feeling much better, do these results indicate the fault as resolved ?
Message 5 of 8
(790 Views)
02-09-2007 2:17 PM
well, it indicates that the profile has uplifted whch should take three days, so it does mean that for 3 days your line has been fault free.
Hope that helps,
Hope that helps,
Message 6 of 8
(790 Views)
02-09-2007 2:31 PM
thank you orbrey.
i'll paste those into the ticket and see what happens, it does seem a bit strange, i've never had my speed fluctuate like that before, it does seem ok now but it won't hurt to get it checked out - there could be something strange going on.
cheers again for great prompt service.
Message 7 of 8
(790 Views)
02-09-2007 4:37 PM
My speed dipped down for a couple of hours earlier today but now seems ok.
Probably a fault with Plusnet that caused it
Message 8 of 8
(790 Views)
