Really poor latency all of a sudden
- Really poor latency all of a sudden
09-02-2012 9:51 PM
Hi, not had any problems before, been on for over a year.
But tonight, it's nearly unusable. Here are my router stats:
A route trace to www.plus.net shows up very high latency:
C:\Users\Charlie>tracert www.plus.net
Tracing route to portal.plus.net [212.159.8.2]
over a maximum of 30 hops:
And lastly, the security log from the router has gone nuts!... (this is just a snippet from the last minute!)
Any help would be greatly appreciated!
Charlie
Quote Downstream Upstream
Data Rate(Kbps)
18272 444
Noise margin (dB)
5.5 29.3
Output power (dBm)
0.0 12.2
Attenuation (dB)
16.0 6.1
Quote 1 2 ms 2 ms 2 ms 192.168.2.1
2 246 ms 231 ms 376 ms lo0-central1.pcl-ag01.plus.net [195.166.128.232]
3 317 ms 411 ms 554 ms gi1-8-112.pcl-gw02.plus.net [84.92.6.2]
4 230 ms 47 ms 49 ms po4.pcl-gw01.plus.net [212.159.1.128]
5 456 ms 365 ms 238 ms ae3.pcl-cr01.plus.net [195.166.129.40]
6 304 ms 476 ms 540 ms ae1.ptw-cr01.plus.net [195.166.129.0]
7 574 ms 417 ms 479 ms te9-4.ptn-gw01.plus.net [195.166.129.33]
8 619 ms 765 ms 706 ms gi3-0.pih-cr1.plus.net [212.159.1.177]
9 472 ms 497 ms 597 ms if25.pih-lb04.plus.net [212.159.0.18]
10 572 ms 555 ms 411 ms portal.plus.net [212.159.8.2]
Quote Feb 9 21:48:49 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 67.190.158.238 117
Feb 9 21:48:49 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 90.148.218.3 115
Feb 9 21:48:50 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 50.15.50.214 115
Feb 9 21:48:51 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 88.255.100.254 117
Feb 9 21:48:51 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 2.5.78.121 113
Feb 9 21:48:51 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 46.120.95.111 116
Feb 9 21:48:51 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 71.23.235.23 115
Feb 9 21:48:51 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 79.107.192.37 116
Feb 9 21:48:51 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 79.131.10.13 115
Feb 9 21:48:52 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 180.216.33.58 116
Feb 9 21:48:52 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 87.194.207.241 117
Feb 9 21:48:52 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 75.118.230.128 117
Feb 9 21:48:52 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 85.192.222.236 117
Feb 9 21:48:52 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 24.246.159.70 116
Feb 9 21:48:52 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 175.142.222.243 118
Feb 9 21:48:53 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 46.120.95.111 116
Feb 9 21:48:53 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 67.166.100.42 116
Feb 9 21:48:53 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 108.67.149.207 117
Feb 9 21:48:53 (none) user.alert kernel: LANDATTACKIN=ppp_0_38_1 OUT= MAC= attack detected from 14.200.214.67 116
Charlie
Message 1 of 5
(1,153 Views)
4 REPLIES 4
Re: Really poor latency all of a sudden
09-02-2012 10:21 PM
I suggest you try a disconnect/reconnect via the router interface.
Are you on a fixed or dynamic IP? If it's dynamic the reconnect should stop the attack.
Message 2 of 5
(475 Views)
09-02-2012 10:32 PM
Excellent! Worked a charm, any idea how I can stop it happening again? Or is it just one of them things?
Message 3 of 5
(475 Views)
10-02-2012 11:34 AM
Unfortunately it's just one of those things - some people will always be scanning large blocks of IP addresses looking for any kind of vulnerability, which is one of the things routers protect against. It's nothing to worry about and as Jelv says if you notice it happening again rebooting the router to get a different IP address will stop things.
Hope that reassures you.
Message 4 of 5
(475 Views)
10-02-2012 2:02 PM
Thank you, glad to say, back to normal today
Message 5 of 5
(475 Views)
