Really lousy speeds, and on the 21CN trial
xyberpix
Hi All,
I hope that someone can help me out on this one, here are my stats from my router:
ADSL Line Type G.DMT
ADSL Line Coding INTERLEAVE
Line Attenuation (Down):63  (Up):31
Noise Margin (Down):7  (Up):7
Total Output Power (Down):17  (Up):12
Current Rate DownStr: 1312(K)  UpStr: 608(K)
ADSL Line Status UP
Relative Capacity Occupation (Down):95  (Up):97
FEC(FAST) (Near):0  (Far):0
FEC(INTERL) (Near):415  (Far):48
CRC(FAST) (Near):0  (Far):0
CRC(INTERL) (Near):7  (Far):0
HEC(FAST) (Near):0  (Far):0
HEC(INTERL) (Near):7  (Far):0
Showtime last(sec) 11240
ADSL_FW_Version ASW_R13_9_38
ADSL_Board_Type ANNEX_A
As you can see these stats are really lousy, can anyone recommend anything at all, I have a high-speed belkin cable (RJ-11), and also one of those BT faceplate add on plates as well, can't remember what they are called at all though, the router is a Linksys AG041.
Thanks in advance for any help, I also have a belkin router, but if I connect that my total output power drops down to 12 and my sync speed drops to 878kb.
scootie
Re: Really lousy speeds, and on the 21CN trial
sry when i surrgested posting here i forgot you where on the adsl2+ trial and you all ready had a thread <a href="http://community.plus.net/forum/index.php/topic,75908.0.html">here</a> any way.
Fixes: 234
[Moderator's note by Adie (Adiewoo) Locked in favour of existing topic]
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
